I have created a c# grasshopper plugin that reads through the grasshopper geometry and writes a report.
I would like to react to any changes in grasshopper (non baked) geometry in the current GH_Document, regardless of how that geometry is created/modified/deleted.
You can access each component’s outputs and check if the value is modified, saving it to some dictionary or something. I’m not familiar with C# in GH.
Another approach maybe is if you check if a component expires (updates). Usually a component is expired when an input is changed. That will trigger re-calculations, but you can’t know if the output value is changed as well.
I was pulled away from this project for awhile. Now I am back with the same question. If Ivelin’s suggestion is a good approach, how do I navigate the components and check for expiration?
