Is there any way to change the background to a solid color using RhinoCommon in R5 ? I have to change it before calling CaptureToBitmap.
This will only work if the current DisplayMode background is set to Use Application Settings… any workarounds?
It doesn’t look like this display mode property can be accessed from RhinoCommon. I’ve added this to the to-do pile.
https://mcneel.myjetbrains.com/youtrack/issue/RH-55138
– Dale
