I get all this by just placing a brand new component in GH canvas
No value for RuntimeMetadataVersion found. No assembly containing System.Object was found nor was a value for RuntimeMetadataVersion specified through options. [1:1]
The type ‘Attribute’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’. [6:12]
The type or namespace name ‘ComVisibleAttribute’ could not be found (are you missing a using directive or an assembly reference?) [7:12]
The type or namespace name ‘ComVisible’ could not be found (are you missing a using directive or an assembly reference?) [7:12]
The type or namespace name ‘GuidAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:12]
The type or namespace name ‘Guid’ could not be found (are you missing a using directive or an assembly reference?) [8:12]
The type or namespace name ‘AssemblyTitleAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:68]
The type or namespace name ‘AssemblyTitle’ could not be found (are you missing a using directive or an assembly reference?) [8:68]
The type or namespace name ‘AssemblyVersionAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:137]
The type or namespace name ‘AssemblyVersion’ could not be found (are you missing a using directive or an assembly reference?) [8:137]
The type or namespace name ‘AssemblyFileVersionAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:182]
The type or namespace name ‘AssemblyFileVersion’ could not be found (are you missing a using directive or an assembly reference?) [8:182]
The type or namespace name ‘AssemblyInformationalVersionAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:231]
The type or namespace name ‘AssemblyInformationalVersion’ could not be found (are you missing a using directive or an assembly reference?) [8:231]
The type or namespace name ‘TargetFrameworkAttribute’ could not be found (are you missing a using directive or an assembly reference?) [8:289]
The type or namespace name ‘TargetFramework’ could not be found (are you missing a using directive or an assembly reference?) [8:289]
Further errors not shown…
System Info:
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Primary display and OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 1GB, Driver date: 8-17-2026 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 26.8.1.260810
> Integrated accelerated graphics device with 5 adapter port(s)
- Windows Main Display attached to adapter port 1
Primary OpenGL: AMD Radeon™ 890M Graphics (AMD) Memory: 1GB, Driver date: 8-17-2026 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 26.8.1.260810
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-17-2026
Driver Version: 32.0.31041.1004
Z-Buffer depth: 24 bits
Total Video Memory: 16444 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
