hi i’m getting an error on one of the c# elements in my gh file:
Error (CS0012): The type ‘Rhino.UI.Interfaces.IGradient’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘Rhino.UI, Version=7.6.21127.19001, Culture=neutral, PublicKeyToken=552281e97c755530’.
the error is pointing at the line:
private Grasshopper.GUI.Gradient.GH_Gradient _gradient;
i’ve tried to search about the error but no luck. would be great if anyone could help. thank you.
