I opened a completely new file and it says the same thing again. does anyone know what is going wrong on this computer, since it is working on my work laptop.
the code seems to fail to compile cryptic C# code from temporary folder with a C# compiler. Why it cannot execute is not specified. It could be that the path to the compiler is hard-coded, but the particular framework version is not installed on your machine, or that the script file is not existing or faulty. I doesn’t tell. Looks strange. Sure that this is intended and not a simplistic way of executing malware on your system? Can you go to the paths and post these files here…
