I want to know if this is a bug or if I’m doing something wrong.
I create a new instance of CRhinoUiOptionsListCtrlPointEditBox, and then I use .SetPoint(double, double,double).
Then I add the item to a ConfigurationCtrl, and I display it in a dialog box, and everything seems to work fine.
But anytime I try to access the instance of CRhinoUiOptionsListCtrlPointEditBox or the item in the ConfigurationCtrl, even immediately after initialized it, I have this bug:
If I use GetPoint() or if I access .x,.y,.z, they all have the same value, which is the .x one, even if y and z are displayed correctly in the dialog box.
This clearly seems a bug to me. Can anyone confirm it? Any way around it to access y and z?
Thank you.
