I am trying to extract outer edges of surfaces. However output is really weird. Let me know what I am doing wrong.
Find attached code and image bellow.
Thanks!
DataTree<Curve> outlines = new DataTree<Curve>();
for(int i = 0; i < iSrf.BranchCount;i++)
GH_Path gp = new GH_Path(i);
for(int j = 0; j < iSrf.Branch(i).Count; j++)
Brep bR = iSrf.Branch(i)[j].ToBrep();
foreach(BrepLoop loop in bR.Loops)
if(loop.LoopType == BrepLoopType.Outer)
outlines.Add(loop.To3dCurve(), gp);
A = outlines;
You could just run Brep.DuplicateEdgeCurves for each face.
Curve[] edges= yourBrepFace.DuplicateEdgeCurves();
This gives me all the edges of Brep. I need outer curves and not interior curves of breps, therefore i used BrepLoop.
menno
(Menno Deij - van Rijswijk)
4
In that case, you could maybe use only the naked edges like so
Curve[] nakedEdges = yourBrep.DuplicateEdges(nakedOnly:true);
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_DuplicateEdgeCurves_1.htm
No, It still shows all the edges. With BrepLoopType.Outer I am able to get outlines but dont understand why the outlines are moved.
Is this Kuwait International Airport?
