Getting the Outline of a Surface
Hey,
I want to get the outlines of a surface in RhinoCommon C#, which is getting me some problems at the moment.
I already got it selected with the GetObject():
GetObject object_selector = new GetObject();
object_selector.SetCommandPrompt(message);
object_selector.GeometryFilter = ObjectType.Surface();
object_selector.Get();
return object_selector.Object(0).Surface;
When selecting the object in Rhino, I get a selection like this:
The Surface I get from Object(0).Surface() however is a rectangle (more exactly a BrepFace):
How can I get the outlines of the first selection?
Thank you a lot for your time.
Brep.DuplicateEdgeCurves sounds like it might be useful for your needs. The link below provides some sample source code as well.
http://developer.rhino3d.com/api/RhinoCommonWin/html/M_Rhino_Geometry_Brep_DuplicateEdgeCurves_1.htm
Here is some sample code that might help you:
https://github.com/mcneel/rhino-developer-samples/blob/master/rhinocommon/cs/SampleCsCommands/SampleCsDuplicateBorder.cs
– Dale
Thanks a lot for your help. I tried out both solutions and got it working now with some tweaking.
What I did was getting all the linear edge curves like in the SampleCsDuplicateBorder (since I only need those) and looked if they are in the BoundingBox I get from the objref.Surface().GetBoundingBox(true):
List FindIntersectingCurves(List curves, Surface surface)
        List<Curve> result = new List<Curve>();
        BoundingBox bbox = surface.GetBoundingBox(true);
        foreach (Curve curve in curves)
            if (bbox.Contains(curve.PointAtStart) && bbox.Contains(curve.PointAtEnd))
                result.Add(curve);
        return result;
Here’s the result:
Thanks again for your quick help :slight_smile:
