So I have and additional tab for 2D drafting where my button commands are edited to set default layers before running the command. In Rhino 7 I edited the buttons with red highlights to differentiate from the standard buttons. I’m trying to do the same with RH8, but the button editor will only edit certain buttons. e.g.
I was able to edit the linear dimensions button. (added Red)
But cannot edit the angled dimension button and most others even as I do the same process as I did before. (Cannot insert red)
I am really hating interacting with this part of Rhino as I cannot understand why many things I use to do, now do not work. Is the a way to export existing button icons, edit in something like Inkscape or Corel, and re-import?
