Hi, When a button design is edited, it seems to turn back to original design. Sometimes you are not able to save the design, other times design jump back to previous design when you change screen or install toolbar on an other computer.
Hei Bjørn,
I don’t do much editing of toolbar buttons but from a brief test here, I was not able to reproduce the issue that you are running into. It sounds a bit like file permissions are getting in the way…
Could you walk me through specific steps that cause the issue on your systems?
Mvh,
Hello - there are three bitmap sizes on an icon - you need to edit all three to cover all the bases. Some setups may show the 24 pixel buttons, others the 32.
Thank you then it works fine
J!!
