I am trying to use the Define Linear Dimension component in Grasshopper from the Elefront plugin to create a vertical dimension, but not having any luck.
If the 2 points are perfectly vertical to each other, the dimension simply disappears. As soon as you move one of the points just a tiny bit out, the dimension appears.
What am I missing here?
Bonus: how can I define the plane in which the vertical dimension appears. The plane for the dimension itself needs to be left blank, but how can I define on what side the dimension comes out. I would like it to show in the YZ plane (currently it shows in the XZ plane).
Adding some offset:
vertical_dimension_bug.gh (20.9 KB)
