BUG: UVN GUMBALL do not undo
Hi @Joshua_Kennedy ,
I’m trying the new gumball on the UVN and to me looks a great improvment but It seems not sensible to Undo. It’s maybe becasue is too new, but still.
My version is: Rhino 9 SR0 2025-8-26 (Rhino WIP, 9.0.25238.12305)
Undo seems to be working for me here. Do you have any more information? Is it a specific type of geometry? Does it happen every time for you? Or only sometimes?
Don’t know. I’m doing it after BlendSrf. Could be a misinteraction between them?
Rhino 9 SR0 2025-8-26 (Rhino WIP, 9.0.25238.12305, Git hash:master @ ba2cf38650b3af8790c8629a1f03c10309209bd2) License type: Commercial, build 2025-08-26 License details: Cloud Zoo Expires on: 2025-10-10 Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB) .NET 9.0.4 Computer platform: LAPTOP - Plugged in [97% battery remaining] Hybrid graphics configuration using OpenGL Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 4-18-2023 (M-D-Y). > Integrated graphics device with 4 adapter port(s) - Windows Main Display is laptop's integrated screen or built-in port Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.88 > Integrated accelerated graphics device with 4 adapter port(s) - Secondary monitor is laptop's integrated screen or built-in port - Secondary monitor attached to adapter port #1 OpenGL Settings Safe mode: Off Use accelerated hardware modes: On GPU Tessellation is: On Redraw scene when viewports are exposed: On Graphics level being used: OpenGL 4.6 (primary GPU's maximum) Anti-alias mode: 4x Mip Map Filtering: Linear Anisotropic Filtering Mode: High Vendor Name: NVIDIA Corporation Render version: 4.6 Shading Language: 4.60 NVIDIA Driver Date: 3-13-2024 Driver Version: 31.0.15.5188 Maximum Texture size: 32768 x 32768 Z-Buffer depth: 24 bits Maximum Viewport size: 32768 x 32768 Total Video Memory: 8188 MB OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64. Rhino plugins that do not ship with Rhino C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp "V-Ray for Rhino" Rhino plugins that ship with Rhino C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp "Commands" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp "Renderer Development Kit" C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp "UpdatesAndStatistics" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp "Rendering di Rhino" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots" C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 9.0.25238.12305 C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse" C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp "Displacement" C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp "SectionTools"
Yes, I can definitely repeat that in your file. But it doesn’t seem to be related to the Gumball. If I open with Gumball disabled, and drag-move any object, it doesn’t undo.
The original file was made in V8.
The blu part were deformed from flat using FlowalogSrf
@skysurfer I’ve created RH-89089 Nothing to undo
There is a test command that seems to fix undo for that file:
TestUndoEnable
I’m on V9 and this is what I get from copy/paste the command
immagine
-R-
sorry, corrected, see above
Yes this works.
Thank you
This is still happening in V9 WIP 9.0.25308.12305, 2025-11-04 and just found your solution.
The TestUndoEnabled made it so I can undo gumball moves but I deleted something on accident and undo did not undo the delete. so not sure this fixes all of my concerns with undo.
Hi Matt -
Do you have a reproducible workflow that we can check?
if I start creating curves and doing stuff undo works and once I start creating hatch the undo stops working after that command.
Hi Matt -
Thanks.
Please post the Rhino SystemInfo command and copy-paste its output here.
When you create the hatch, and then save and close the file, does undo then still not work when you open the file and move those hatches?
When the file is saved and re opened the undo functionality is not restored.
system info.txt (2.7 KB)
Just updated and it seems to be fixed. (9.0.25322.6305, 2025-11-18)
Hi Matt -
Yes, this was RH-90457 Annotation Hatch: Creating a hatch clears previous undo stacks
