Bug! Right mouse click on layers on Mac Rhino
Hi all,
I have noticed the right mouse click doesn’t do anything on Mac Rhino8. There are no popup windows.
W
Hi @woojsung
Pls run _SystemInfo in Rhino and post back the results
Hello, same issus here, it is very time consuming to quit rhino everytime this happen.
Thanks for any help
Here are my system info
Rhino 8 SR15 2025-1-13 (Rhino 8, 8.15.25013.13002, Git hash:master @ 424331904354085c3cb84eda50bc6e3d92d470f4)
License type: Commercial, version 2025-01-13
License details: Cloud Zoo
Apple macOS Version 14.5 (assemblage 23F79) (Physical RAM: 32GB)
Mac Model Identifier: Mac14,6
Language: fr-FR (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
LG HDR 4K (3008 x 1692 @ 60.00Hz)
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
VIA Technologies Inc. : USB 2.0 BILLBOARD
Apple Inc.: Apple Keyboard
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Library/Chaos/Enscape/Enscape.Rhino.Plugin-net48/libSkiaSharp.dylib
/Users/cyriac/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp “Enscape.Rhino8.Plugin” 4.2.1.88
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rendu de Rhino” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Ancien rendu de Rhino” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.15.25013.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.15.25013.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.15.25013.13002
Hi Cyriac -
Does that mean that the behavior is different when you have quit Rhino and restarted?
If so, do you know what triggers the behavior?
Is it something that you often run into?
What happens when you disconnect the external screen and only use the laptop’s screen?
Yes indeed, once restarted, it functions as usual. After several manipulations on the layers the problem happens again and so i have to restart rhino. Several colleagues of mine are facing the same issue at the office. It is very hazardous: i manage to spend the day without this issue and it’s starting again now. It has to be fix. I tried without my external screen, same thing…
Also, with that same issue, it becomes impossible to move one layer in the layer list, from a group to another for example. It seems to be a general “layer bug”, really weird and annoying.
