Bug: Rhino 8 doesn't refresh Layer UI when removing layer material
When setting a layer material to some material from the library, the Layers panel shows the new material, as expected. Clearing the layer material (resetting it to Default Material) doesn’t update the Layers panel until the file is reopened.
Correct display:
The Layers panel is out of sync after resetting the material:
To reproduce:
  1. Create a new model, add some geometry to the active layer
  2. Change the active layer material (in the Layers panel) to some material
  3. Observe that the Layers panel shows the correct material
  4. Change the active layer material to the Default Material
  5. Notice that the Layers panel still shows the previously assigned material
System Info:
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092)
License type: Commercial, build 2025-10-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.21
Computer platform: LAPTOP  - Plugged in \[100% battery remaining\]
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\\Program Files\\Rhino 8\\Plug-ins\\Commands.rhp	“Commands”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\WebBrowser.rhp	“WebBrowser”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk.rhp	“Renderer Development Kit”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoScript.rhp	“RhinoScript”
C:\\Program Files\\Rhino 8\\Plug-ins\\AnimationTools.rhp	“AnimationTools”
C:\\Program Files\\Rhino 8\\Plug-ins\\IdleProcessor.rhp	“IdleProcessor”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRenderCycles.rhp	“Rhino Render”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRender.rhp	“Legacy Rhino Render”
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk_etoui.rhp	“RDK_EtoUI”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\NamedSnapshots.rhp	“Snapshots”
C:\\Program Files\\Rhino 8\\Plug-ins\\MeshCommands.rhp	“MeshCommands”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCycles.rhp	“RhinoCycles”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\Toolbars\\Toolbars.rhp	“Toolbars”	8.24.25281.15001
C:\\Program Files\\Rhino 8\\Plug-ins\\3dxrhino.rhp	“3Dconnexion 3D Mouse”
C:\\Program Files\\Rhino 8\\Plug-ins\\Displacement.rhp	“Displacement”
C:\\Program Files\\Rhino 8\\Plug-ins\\SectionTools.rhp	“SectionTools”
Thanks for report @gyorgy.bozoki. I’ve logged the issue.
– Dale
RH-90141 is fixed in Rhino 8 Service Release 25
Thank you @dale and @brian .
