BUG?: Query Model Objects - Null ID
I got very strange results out of Query Model Objects which breaks my solution. Can somebody please tell me if it’s a bug? Many curves from my scene do not output ID when using the Content Details component.
It has to be bug, because everything went back to normal after reopening the file. There also might be something with Content Cache Push / Pull that I don’t know yet.
System Info
Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01001, Git hash:master @ 6957666ece3a5f3ed7694c0ca66cdfea0407df3a)
License type: Educational, build 2024-08-20
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Synapse\0.4.0\SynapseRCP.rhp “SynapseRCP” 0.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24233.1001
null objects.gh (8.8 KB)
null objects.3dm (77.8 KB)
Valid objects marked white.
not seeing the issue in our latest daily (8.12), lets start troubleshooting by disabling 3rd party plugins in Rhino. You may need to also initiate grasshopper with the Rhino command line GrasshopperLoadOneByOne and say no to 3rd parties if the Rhino plugin remove doesn’t clear it up.
Thanks, I can reproduce it in 8.12. Later I will dig in it and check how I can narrow it down.
PS
I had just a while now, rolled back to 8.10.24212.13001 and so far I can’t reproduce it using this version.
I don’t think it’s plugin related. I made a very simple definition that you can use to reproduce this problem. Please take a quick look and if it will work differently on your computer then I will dig deeper. For me it looks like something must have changed with the Content Cache in 8.11
8.10.24212.13001 - working
8.11.24226.06001 - not working (restarting Rhino solves the problem)
cache test.gh (11.2 KB)
null objects.3dm (65.8 KB)
Change the user text key value of one object from Rhino Panel while having Content Cache’s Push set to True.
Hi @Czaja,
This is fixed in the 8.11 that will be available next Tuesday.
