BUG: Content Cache component hangs Rhino
Rhino 8.11.24233
System Info
Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01001, Git hash:master @ 6957666ece3a5f3ed7694c0ca66cdfea0407df3a)
License type: Educational, build 2024-08-20
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 4-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.59
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 4-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.59
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-15-2024
Driver Version: 31.0.15.3859
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Synapse\0.4.0\SynapseRCP.rhp “SynapseRCP” 0.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24233.1001
Once I open GH definition with Query Model Objects I can no longer modify object visibility in Rhino. Note, that Grasshopper is locked and I opened a new GH definition. Changing visibility in this case can take a few minutes, although there are only 300 block instances in the file.
If I completely shut down the GH file, everything went back to normal.
Files sent to tech support.
I have been messing with this file in 8.10 Rhino. Performance seems fine at the moment, Although I have not done any Content Cache activating yet.
Is there a set of steps that can be taken to slow it down?
The top Query is finding 83 instances. The lower query is finding 249 instances.
Can you run Systeminfo in Rhino so we can see what the hardware versions look like?
This is mine:
Rhino 8 SR10 2024-8-15 (Rhino 8, 8.10.24228.13001, Git hash:master @ f4c93f2b85de4dc69b50ed22f1b0d91445724d03)
License type: Commercial, build 2024-08-15
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.7
Hi Scott,
I’m always putting System Info wrapped by using Discourse “Hide Details” - It helps keep my posts more compact. You probably just overlooked it, please click on it and you will have all the info.
Everything needed to reproduce this problem is shown in the video. Just open the GH file and try to hide some objects, then use ShowSelected, etc. Rhino should hang for a good few minutes.
So, by skipping the show selected undo process before the GH definition is run, then is it fast?
Trying to track if this is an undo stack issue. We have some tools to see what is happening there if it seems the numbers of undo steps are causing trouble.
I will try and repeat this. I see this is 8.11 now. Will need to get that first.
I updated Rhino to version 8.11.24240 and decided to play a bit more with it.
Actually, it seems that the Content Cache is making the worst hangs. Query Model Objects components take a while to update, so it’s only a stutter. Not only Showing/Hiding or Undo/Redo is slow, but also a simple Gumball move is forcing the Content Cache component to recalculate something. From what I saw, and what is visible in the video, modifying Rhino Object visibility is making Rhino hang for much longer than moving objects. I observed a similar, long hang when entered Block Edit mode.
The content Cache component is not pushing changes all the time it’s in a form that pushing the button needs to be done for it to work.
This is rather slow for less than 300 blocks. I’ll get a youtrack started.
Thanks, can someone explain what is happening with the Content Cache in the background? I appreciate the new tools and workflows but Grasshopper is much more less wysiwyg than it used to be. Locking the solver and switching to other GH documents is not enough to avoid several minutes of hangs during a very easy Rhino operation. This is very unintuitive.
Japhy, how long do the hangs last if you repeat what I do in the file - mainly talking about show/hide/showselected operations?
Its taking about 3 1/2 - 4 minutes to complete a push that changes the Visibility on the 350 blocks.
Here is the youtrack for RH-83545
Its writing to the various tables in Rhino. Let’s see what Kike finds with this issue, it may be unrelated to content cache component itself.
There was a hotfix this morning in 8.11, +. My initial tests have the same process completing in less than 5 seconds.
Brief test of the daily build 8.12.24242.06001 showed that the problem still persists. Did you try also playing with the ShowSelected Rhino command while having the Content Cache component enabled?
I was trying to roll back to 8.10.24226.13001, but it’s crashing Revit 2023.1 (works ok with the Revit 2022…), earlier versions do not even run with Revit 2023.1, I don’t remember why. I’m really looking for some stable build to work with.
To be clear, you are talking about the Show Selected preview correct?
I’m not seeing any differences
No, ShowSelected Rhino command to unhide selected Block Instances. It can be also Hide command as shown in my videos. Basically changing the visibility attributes using Rhino commands of object referenced in Content Cache.
Got it, that is a different issue, hopefully it’s as easy to rectify as the last.
Its doesn’t seem to be the query components, isolating those into a new file doesn’t slow down with hide/show rhino actions. Your full visibility definition on the other hand does, without anything that else that would be affected by the action.
In the middle of the topic I realized that it’s a Content Cache component rather than Query Model Objects and changed the title. Please let me know when it will be solved. Thanks for the help.
It’s fixed on the next 8.11
Japhy sent me this version and I confirm, it works very fast now. Thank you very much.
This usability problem might also interest you. Rather slow behavior if I enter Block Edit mode. It seems that query goes one by one with every locked object.
Thanks Jakub, I was able to repeat and filed a youtrack RH-83871
RH-83871 is fixed in Rhino 8 Service Release 12
