Bug of ON_Brep::Tranform() or CRhinoDoc::ReplaceObject() ? c++
Hi;
    CRhinoGetObject go;
	go.SetCommandPrompt(L"Select Breps");
	go.EnableReferenceObjectSelect(false);
	go.EnableSubObjectSelect(false);
	go.EnableGroupSelect(true);
	go.SetGeometryFilter(ON::brep_object);
	go.GetObjects(1, 0);
	if (go.CommandResult() != CRhinoCommand::success)
		return go.CommandResult();
	ON_3dVector ve_move(5.0, 5.0, 0.0);
	ON_Xform xf_move = ON_Xform::TranslationTransformation(ve_move);
	ON_Xform xf_sc = ON_Xform::ScaleTransformation(ON_Plane::World_xy, 3.0, 3.0, 1.0);
	ON_SimpleArray<CRhinoObject*> ObjectList;
	for (int i = 0; i < go.ObjectCount(); i++)
		ON_Brep* br = go.Object(i).Brep()->Duplicate();
		br->Transform(xf_move);
		ObjectList.Append(RhinoApp().ActiveDoc()->AddBrepObject(*br));
		br->Transform(xf_move * xf_sc);                // seems to be failing to Scale
		RhinoApp().ActiveDoc()->ReplaceObject(ObjectList[i], *br);
The_file.3dm (61.0 KB)
My code seems to be failing to Scale objects, I kown RhinoApp().ActiveDoc()->TransformObject() can be transform good, but it can not use in History.
What I want to know is is there a good way to implement my own transform function ?
Hi @suc_kiet,
Maybe this?
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
  CRhinoGetObject go;
  ON_3dVector dir(5.0, 5.0, 0.0);
  ON_Xform xf_move = ON_Xform::TranslationTransformation(dir);
  ON_Xform xf_scale = ON_Xform::ScaleTransformation(ON_Plane::World_xy, 3.0, 3.0, 1.0);
  ON_Xform xf_final = xf_move * xf_scale;
    const CRhinoObject* obj = go.Object(i).Object();
    if (obj)
      context.m_doc.TransformObject(obj, xf_final, true, true, true);
  context.m_doc.Redraw();
  return CRhinoCommand::success;
Hi @dale,
Sorry, I didn’t describe it clearly, I’m uploading the code again now.
class CCommandTest : public CRhinoScriptCommand
public:
	CCommandTest() = default;
	UUID CommandUUID() override
		// {C1BEC3E3-4DAA-45AC-A02D-9F1FD3944D36}
		static const GUID TestCommand_UUID =
		{ 0xC1BEC3E3, 0x4DAA, 0x45AC, { 0xA0, 0x2D, 0x9F, 0x1F, 0xD3, 0x94, 0x4D, 0x36 } };
		return TestCommand_UUID;
	const wchar_t* EnglishCommandName() override { return L"TransformHistory_Test"; }
	CRhinoCommand::result RunCommand(const CRhinoCommandContext& context) override;
	CRhinoObject* ReplayHistory(const class CRhinoHistoryRecord& history_record);
	bool WriteHistory(
		CRhinoHistory& history,
		CRhinoObjRef obj0,
		ON_Xform mxf);
	bool ReadHistory(
		const CRhinoHistoryRecord& history_record,
		CRhinoObjRef& obj0,
		ON_Xform& mxf);
	static const int m_sample_history_version;
static class CCommandTest TestCommand;
const int CCommandTest::m_sample_history_version(20220122);
bool CCommandTest::WriteHistory(
	CRhinoObjRef Crv0,
	ON_Xform mxf)
	if (!history.SetObjRefValue(0, Crv0))
		return false;
	if (!history.SetXformValue(1, mxf))
		return false;
	history.SetHistoryVersion(m_sample_history_version);
	return true;
bool CCommandTest::ReadHistory(
	CRhinoObjRef& Crv0,
	ON_Xform& mxf)
	// Check to make sure this history record was made with this version
	if (m_sample_history_version != history_record.HistoryVersion())
		return false;
	if (!history_record.GetRhinoObjRef(0, Crv0))
		return false;
	if (!history_record.m_hr.GetXformValue(1, mxf))
		return false;
	return true;
CRhinoObject* CCommandTest::ReplayHistory(const class CRhinoHistoryRecord& history_record)
	CRhinoObjRef Crv0;
	ON_Xform mxf;
	if (ReadHistory(history_record, Crv0, mxf))
		if (Crv0.Object() != nullptr)
			//xf_Global = mxf;      //In my Plugin, I must get the history transformation in this position
			CRhinoObject* result = nullptr;
			CRhinoDoc* doc = Crv0.Object()->Document();
			if (0 == doc)
				return result;
			result = doc->TransformObject(Crv0, mxf, false, false, false);// This position will cause rhino to crash
			return result;
	return 0;
	CRhinoGetObject go;
	ON_2dexMap grmap;
		ON_Xform xf = xf_move * xf_sc;
		CRhinoHistory history(*this);
		WriteHistory(history, go.Object(i), xf);
		CRhinoObject* obj = RhinoApp().ActiveDoc()->TransformObject(
			go.Object(i), xf, false, false, false);
		if (obj != nullptr)
			obj->SetHistory(history);
			RhinoUpdateObjectGroups(obj, grmap);
I mainly want to get transformation from the history record, but the TransformObject() funtion will cause rhino to crash when used it in history, That’s why I want to use the ON_Brep::Transform() function :smiley:
