seppeldue
(Seppeldue)
August 21, 2020, 9:21am
1
i try to perform a transformation on several SubObjects, but transformation is done to the whole object and not the subobject… do i have to get an ObjRef for all possible cases? If so can they all be stored in one list?
GetObject go = new Rhino.Input.Custom.GetObject();
go.SubObjectSelect = true;
go.GetMultiple(1, 0);
doc.Objects.Transform(go.Object(i), xform, true);
thanks
For Breps you can use Brep.TransformComponent like this:
//C#
var go = new GetObject {GeometryFilter = Rhino.DocObjects.ObjectType.Surface, SubObjectSelect = true};
go.SetCommandPrompt("Select brep-face to transform");
go.Get();
if (go.CommandResult() != Result.Success) return go.CommandResult();
var objref = go.Object(0);
var brep = objref.Brep();
var xform = Transform.Scale(Plane.WorldXY, 1.2, 1.2, 1.2);
brep.TransformComponent(new []{objref.GeometryComponentIndex},xform, doc.ModelAbsoluteTolerance, 0, true);
doc.Objects.Replace(objref.ObjectId, brep);
doc.Views.Redraw();
return Result.Success;
#python
import Rhino
from scriptcontext import doc
def TransformSubObj():
go = Rhino.Input.Custom.GetObject()
go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
go.SubObjectSelect = True
go.Get()
if go.CommandResult()!=Rhino.Commands.Result.Success:
xform = Rhino.Geometry.Transform.Scale(Rhino.Geometry.Plane.WorldXY, 1.2,1.2,1.2)
brep.TransformComponent([objref.GeometryComponentIndex],xform, doc.ModelAbsoluteTolerance, 0, True)
doc.Views.Redraw()
if __name__ == "__main__":
TransformSubObj()
TransformSubObj.py (736 Bytes)
TransformSubObj.zip (94.4 KB)
