If I am using a custom filter for a solid object, accepting extrusion objects must be explicitly programmed. Open a new file and make a box or other extrusion object. Do not preselect the object at first. Then run:
def solid_filt(rhino_object, geometry, component_index):
return geometry.IsSolid
msg="Select a solid object"
obj=rs.GetObject(msg, 8+16, preselect=True, custom_filter=solid_filt)
if obj: print "Object selected"
else: print "Nothing selected"
You will not be able to post-select the extrusion based box. If you convert it to a polysurface, you can. Also, paradoxically, if you preselect the extrusion, it passes!
Now, if you add the extrusion object explicitly to the main selection filter, it works.
obj=rs.GetObject(msg, 8+16+1073741824, preselect=True, custom_filter=solid_filt)
Pre- or post- selecting an extrusion object with just the basic surface+polysurface filter (8+16) also works if there is no custom_filter…
–Mitch
