Hi All,
There is strange behavior of object selection within block instance.
I have the block instance that contains 3 objects: polysurface, extrusion and mesh.
I would like implement feature of sub-object selection (to be able select custom number of sub-objects) with command that contains next code:
But the problem is the extrusion can’t be selected.
Even if selection filter has extrusion bit enabled and sub-object selection is allowed.
What can be wrong? Thanks for any ideas.
Hi Dale,
Yes, it seems your code can be a solution of my problem, thanks.
One note connected to selection problem:
According to description of the function: void CRhinoGetObject::EnableSubObjectSelect(BOOL bEnableSubObjectSelect, BOOL bEnableBlockSubObjectSelect);
I expected that with the next code line: go.EnableSubObjectSelect(FALSE, TRUE);
it can be possible to select sub-objects of a block instance. But it isn’t so.
Only lines: go.EnableSubObjectSelect(TRUE);
or go.EnableSubObjectSelect(TRUE, TRUE);
allow sub-object selection.
Are the function parameters managed independently or the second parameter depends on the first?
