Bug: Crashes when closing after exporting a DWG file
Hi McNeel
@Japhy
I have an issue where Rhino crashes after exporting a DWG file. It does not crash during the export, but it crashes when I try to close Rhino afterward.
It doesn’t matter what I try to export or if I export from the command line or using RhinoCommon.
I think this is a Rhino for Mac issue.
Version 8.10.24226.13002
Not seeing the issue on a quick test in 8.11 on Sonoma.
Please run SystemInfo and post the result.
Does this happen in a fresh file with a simple rectangle as well or just particular files?
Hi Japhy
Thank you for getting back to me.
Systeminfo.txt (4.2 KB)
I think it is a general thing. It happens for this file.
test.3dm (36.0 KB)
ExportAll
On closing the application
looking at your recent crash reports now, can you disable enscape and restart Rhino and try again? These were from last week on 8.9
Never mind, i can repeat. Thanks for reporting
Perfect. Thank you Japhy.
Thanks for logging this Japhy. Just closing the loop here, this is:
RH-83419 Rhino app crash dwg export
