BUG: clash does not work with blocks
I wanted to use clash to detect collisions. Unfortunately you cannot select block instances for that…
thanks Ivan for reporting:
RH-78497 Block instances cannot be used in clash detection
just discovered the clash command, helps a lot in big assemblies.
please add support for Blocks as well!
as a workaround I am using external files attached as worksession reference.
Thanks
