walther
(Andreas Walther)
September 9, 2024, 10:39am
1
I don´t know if I just don’t get it, but history in booleans does not seem to work for me…
Simple setup:
2 intersecting boxes
click on “record history” (button is shaded)
execute “boolean difference”
select box A then box B (delete input=yes delete cutters=no), enter
select and move box B → no update!
however if I have delete input=no enabled it works, but I don´t want that…
Can someone enlighten me ?
Thanks
Andreas
Gijs
(Gijs de Zwart)
September 9, 2024, 10:46am
2
any command in Rhino that deletes (part) of the input will break history. I think the best you can do is keeping box A on a different layer and hide that layer after the Boolean operation.
walther
(Andreas Walther)
September 9, 2024, 10:51am
3
Thanks Gijs,
that´s exactly what I am doing now…
But I do not understand this behavior at all, confusing IMHO
Why should we have to keep a copy of operand A?
At least there should be some kind of warning that boolean history failed.
Is there any documentation describing this shortcoming? When I searched the help files it basically just says boolean history works now…
Best
Andreas
i agree, playing with that yesterday it was a confusing shortcoming. i ended up hiding the copy .
does it not? it should, it does on mac
Gijs
(Gijs de Zwart)
June 30, 2025, 1:12pm
5
RH-88186 Boolean Difference: UX
