BUG - BETA - Multiple Casting Errors (Model Objects)
In testing the latest Beta build there are multiple errors when casting between various Model Objects.
Failures discovered so far:
-Model Point → Plane
-Model Curve → Curve
I can put a Point container between the Model Point and Plane components and it works
I can put a Line container between the Model Curves and Curve components and it works (for line objects)
Please see errors here:
To repeat, use the Query Model Objects component and try connecting some vanilla GH nodes to the outputs
Thank you!
@wim @Gijs @AndyPayne @kike
This should be fixed in the next Beta release.
Thanks Andy!
EDIT:
Just tested in this afternoons Beta build and all the casting errors I found are indeed fixed.
Thank you!
