I am parsing STEP format files and I am unsure where to position spline knots in space. I have read a wiki and the rhino doc page about B-Spline geometry, and I have read the disclaimer that it is common to mistakenly associate knots with control points. There is no designation for type of BSpline Curve or type of knots ( they are described as unspecified in the text file) exported from Pro/E.
I have a knot vector of length #controlpoints + degree + 1, my current strategy is to set the first knot to the first control point, the last knot to the last control point; and then to evenly distribute the rest. Is there a more correct way to do this with the amount of information available?
NURBS in STEP files usually have knots, but I believe it is possible to have an implied knot vector, in which case the knots would probably be assumed to be 0, 1, 2, … if “uniform” is part of the entity name. “Unspecified” would lead me to expect a knot vector to be present in the file.
Knots and CVs are stored independently. There is no notion of assigning a knot to a CV. Just stick the knots in m_knot (after dealing with the superfluous issue), and the CVs in m_CV.
