Brep.CreateBoolean... performances V8 vs. V7
Create the model with this Python 2 script.
import Rhino.Geometry as rg
import scriptcontext as sc
def main():
    points = rs.coerce3dpointlist((
        ( 0.0,  0.0,  0.0),
        ( 0.0,  5.0,  0.0),
        ( 0.0, 10.0,  0.0),
        ( 5.0,  0.0,  0.0),
        ( 5.0,  5.0, 10.0),
        ( 5.0, 10.0,  0.0),
        (10.0,  0.0,  0.0),
        (10.0,  5.0,  0.0),
        (10.0, 10.0,  0.0),
    ns = rg.NurbsSurface.CreateFromPoints(
        points,
        uCount=3,
        vCount=3,
        uDegree=2,
        vDegree=2)
    brep = ns.ToBrep()
    breps = []
    for i in range(100):
        for j in range(100):
            brep_Trans = brep.DuplicateBrep()
            brep_Trans.Translate(rg.Vector3d(10.0*i, 10.0*j, 0.0))
            breps.append(brep_Trans)
    brep_Joined = rg.Brep.JoinBreps(breps, tolerance=2*sc.doc.ModelAbsoluteTolerance)[0]
    sc.doc.Objects.AddBrep(brep_Joined)
    sc.doc.Views.RedrawEnabled = False
    rs.AddCylinder((5,5,0), height=10, radius=2, cap=True)
    sc.doc.Views.RedrawEnabled = True
if __name__ == '__main__': main()
Test the model with this Python 2 script.
from future import absolute_import, division, print_function, unicode_literals
import Rhino
from System.Diagnostics import Stopwatch
def main():
gA = rs.GetObject("Select brep A", filter=rs.filter.polysurface, preselect=True)
if gA is None: return
gB = rs.GetObject("Select brep B", filter=rs.filter.polysurface)
if gB is None: return
rgA_In = rs.coercebrep(gA)
rgB_In = rs.coercebrep(gB)
Rhino.RhinoApp.SetCommandPrompt("Working ...")
sw = Stopwatch()
sMethods = (
    "rg.Brep.CreateBooleanUnion([rgA_In, rgB_In], tolerance=2.0*sc.doc.ModelAbsoluteTolerance)",
    "rg.Brep.CreateBooleanDifference(rgA_In, rgB_In, tolerance=2.0*sc.doc.ModelAbsoluteTolerance)",
    "rg.Brep.CreateBooleanIntersection(rgA_In, rgB_In, tolerance=2.0*sc.doc.ModelAbsoluteTolerance)",
for sMethod in sMethods:
    sw.Restart()
    rgB_Res = eval(sMethod)
    sw.Stop()
    print("{} ms for {}".format(sw.ElapsedMilliseconds, sMethod.split('(')[0]))
    if rgB_Res is None:
        print("{} failed.".format(sMethod.split('(')[0]))
if name == ‘main’: main()
Picking the larger brep for brep A and the cylinder for brep B, I get these results:
8.8.24163.12481, 2024-06-11
2951 ms for rg.Brep.CreateBooleanUnion
2999 ms for rg.Brep.CreateBooleanDifference
260 ms for rg.Brep.CreateBooleanIntersection
7.37.24107.15001, 2024-04-16
215 ms for rg.Brep.CreateBooleanUnion
2835 ms for rg.Brep.CreateBooleanDifference
247 ms for rg.Brep.CreateBooleanIntersection
Picking the breps in reverse (cylinder then other):
2981 ms for rg.Brep.CreateBooleanUnion
216 ms for rg.Brep.CreateBooleanDifference
214 ms for rg.Brep.CreateBooleanIntersection
233 ms for rg.Brep.CreateBooleanUnion
505 ms for rg.Brep.CreateBooleanDifference
I didn’t include them in the test, but the UI commands, _BooleanUnion, _BooleanDifference, and _BooleanIntersection, all execute in significantly less times in both V7 and V8.
Hi @spb,
Have you benchmarked Python3 in V8?
– Dale
8.8.24170.13001, 2024-06-18 Python3 results are similar to Python2 in V8.
Picking large brep then cylinder:
2866 ms for rg.Brep.CreateBooleanUnion
2944 ms for rg.Brep.CreateBooleanDifference
251 ms for rg.Brep.CreateBooleanIntersection
Picking cylinder then large brep:
2916 ms for rg.Brep.CreateBooleanUnion
214 ms for rg.Brep.CreateBooleanDifference
213 ms for rg.Brep.CreateBooleanIntersection
Hi @spb,
The results you’re getting are not a whole lot different than what I’m getting.
results.txt (1.1 KB)
– Dale
So, V8’s RhinoBooleanUnion and rg.Brep.CreateBooleanUnion take about 10x the time of V7 to complete. I didn’t find a relevant issue in YouTrack.
I’m getting there.
https://mcneel.myjetbrains.com/youtrack/issue/RH-82742
– Dale
Hi @spb,
We’ve pushed a fix into Rhino that will appear in Rhino 8 SR10. When you see a release candidate available, you might give it a go.
– Dale
