Hi All, Greetings!
I have many different curves, one of which is shared below. I want to break that curve into pieces (i want to break curve when there is sudden change or near to sudden change in the curve) . I tried explode command (Just to see if it works, before trying on python) but didnot work. I request if someone can help me to achieve this using rhinopython
The constraint is that i cannot have manual intervention. It should all be done automatically.
I can create point grid on the curve but rest all should happen without manual intervention.
Hi Siemen,
As there were sharp change near by those blue lines (i.e, before and after), so i did not choose it. But i am still okay, if those gets identified.
It seems to me that any decision on cut location needs to be based on the local curvature. Perhaps by sampling the curvature as a function of the curve parameter at sufficient density for your task you could then find local maxima and split there. I haven’t checked, but perhaps RhinoCommon has functions that will help you do that.
