Hello!
i’ve got a problem on a python script…
i have a lot of steel frame, in a doc, and i want to list them with a python script,
so my script take all metal tube, and make a bounding box around to give the lenght, and the section, but i’ve got a difference i think it’s the tolerance, but i don’t know where…
# coding: utf-8
def Orientation_Plane(Tube):
ArrSurf=rs.ExplodePolysurfaces(Tube)
Area=0
for Surf in ArrSurf:
AreaSurf=rs.SurfaceArea(Surf)
if AreaSurf[0]>Area:
BigSurf=Surf
Area=AreaSurf[0]
ArrEdge=rs.DuplicateEdgeCurves(BigSurf, select=False)
Lg=0
for Edge in ArrEdge:
LgEdge=rs.CurveLength(Edge)
if LgEdge>Lg:
BigEdge=Edge
Lg=LgEdge
UDom=rs.SurfaceDomain(BigSurf,0)
VDom=rs.SurfaceDomain(BigSurf,1)
NormSurf=rs.SurfaceNormal(BigSurf,((UDom[1]-UDom[0])/2,(VDom[1]-VDom[0])/2))
Origine=rs.CurveStartPoint(BigEdge)
XVect=rs.CurveEndPoint(BigEdge)-rs.CurveStartPoint(BigEdge)
Plane=rs.PlaneFromNormal(Origine,NormSurf,XVect)
#rs.AddPlaneSurface(Plane, 500,500)
rs.DeleteObjects(ArrEdge)
rs.DeleteObjects(ArrSurf)
BBox=rs.BoundingBox(Tube,Plane)
rs.AddBox(BBox)
print 'longueur', int(Lg)
print 'Section', int(rs.Distance(BBox[3],BBox[0])),'x',int(rs.Distance(BBox[4],BBox[0]))
ArrTube=rs.GetObjects("selectionne l'ensemble des tubes")
PrefixTube=rs.GetString("une lettre de nommage?")
for Tube in ArrTube:
it’s for square tube, i draw 70 x 70 square with 2000 lenght, and some times it’s returns 2000 x 70 x 69…
maybe you will see where is the matter…
