Is there a way to extract the boundary of va window by gh directly in a window position (on wall surface)?
See attached
Thank you
Hi @fn_a,
You can use the VisualARQ Labs “Extract Curves” command: https://www.visualarq.com/labs/#vaExtractCurves.
Thank you @alfmelbev,
but I need to implement it in Grasshopper. Do you have the same solution there?
Thank you again
Hi @fn_a find attached the gh file used for the vaExtractCurves command in the VisualARQ Labs.
It not only works for doors and windows but also for walls, curtain walls, slabs, etc…
vaExtractCurves.gh (73.8 KB)
