I have this set of points (with no order):
I want to obtain the boundary polyline:
PointsBoundary.gh (1.8 KB)
I think the easiest way is to manually draw a curve that “more or less” follows the order of the points, then use Sort along Curve to sort the points and Polyline them, something like:
Thanks, @inno. I know that is a solution, but I want to obtain it without user intervention
How do you get the point order ?
That’s what I don’t know
I could think about something like a big blob-like closed curve that progressively shrinks in such a way to enclose the most external points together:
but regarding those very random inlets… even the polyline you have drawn yourself appears like one of the many possible solutions, expecially on the top part… I could draw many different non-intersecting ones, wouldn’t know why to chose that particular one you have drawn among the many possibilities:
There is only one possible solution, the only polyline that goes over all points (leaves no point inside) and doesn’t cross itself
One way to define this… polyline through all points and minimal area difference to convex hull?
Shortest polyline through all points… minimal difference to convex hull
That would still discount their desired solution. I don’t see how you’d preferentially choose that big detour on the bottom vs. a little one on the top.
You’re right
And what if I have some geometry inside the boundary and it cannot cross the boundary?
PointsBoundary_v2.gh (4.0 KB)
