Boolean Union + Split problems
Hi guys,
I am having difficulties trying to boolean join two surfaces together. I’ve looked at the intersect feature and they do indeed intersect and it shows me the resulting curve. Yet, when I try to boolean them together it is unable to do so.
Hello - Please attach a file with the two objects or send to tech@mcneel.com if the file is confidential.
Rhino_Tutorial_3 (1).3dm (3.9 MB)
I am trying to boolean union the object in yellow and green first. then join the object in pink to the first set of boolean union
Hello - the yellow object has multiple coincident faces - you’ll want to explode and simplify that.
@sri.c.gowda - see
I’m not sure I understand. Can you explain how to do that?
Thank you!
