Boolean union and subtract - intersecting cylinders
I would like to join two elements together but can’t seem to work it out, intersecting the components doesn’t work… I’ve tried splitting and intersecting, trimming… I don’t want to use a slightly smaller cylinder if I can help it.
Any ideas how I can intersect these two?
Ring_01.3dm (442.8 KB)
Hmmm… I was expecting at least some solution or work around :blush:
I can see where the pinch points are, it’s a tricky one.
Continuing the discussion from Boolean union and subtract - intersecting cylinders:
Ah… I was able to split it down the middle along the horizontal axis and then trim the shapes…
Ring_02.3dm (388.2 KB)
Hi 2DCube- when Boolean operations fail, the first thing to do is check the curve(s) of intersection among the objects - that will usually give a good clue as to what is going wrong. In this case, three intersection curves are returned, but not all of the expected ones… i.e. a bug. Your solution is fine…
http://mcneel.myjetbrains.com/youtrack/issue/RH-31077
