how can i combine these two halves without altering the shape of the ring? any help is appreciatproblem ring.3dm (729.3 KB)
This two surfaces causes the boolean fail, if you split them somewhere close to the intersection, it will work
aha really clever solution, i was able to help but in zbrush since i dont really use rhino much these days, zbrush just combined them now am left with the mesh but perfectly combined, will pass this along but looks like a nice solution
this also works in Rhino, if you convert to mesh, the boolean works fine.
thanks again
