I assume the geometry in the file is “baked” from Grasshopper and, thus, not the actual input to the function above? What we probably need is a .gh file that isn’t working.
Hi Dale
Well it’s a bit more complex than that. I am writing some custom components
in grasshopper , these objects are the result of custom code written in C# , I will see if able to make a small
gh file.
I am quite sure there is something wrong with the plate, if the object is exploded , after deleting
the unwanted parts and rebuilding the surface edge tolerances it has a weird behavior in Rhino.
I am investigating this object to see where the problem is, basically it is built from a line and a extrusion path.
The line is offset in a plane to generate a closed profile (top and bottom lines added to the left-right offset) then transformed into final position and extruded along the path.
Hi Dale
In this file I was able to get the parts involved.
If the rectangle is extruded into a solid using the “Extrude planar curve along curve” and the line as the extrusion path we get a plate.
Boolean subtract the cylinder from the plate fails with a “breps do not intersect message”
Forget the previous message
The failure is due to a bad tolerance value in options
Setting it to 0.001 fixed the issue , so I am back to my original problem
I think that I have found the source of the problem. In this example the plates are built out of a closed profile
and extruded along a path. The boolean operation becomes a union or a subtraction if the polyline orientation is flipped from ccw to cw. So it seems that I have to check orientation of the profile based on the extrusion direction to get a valid oriented brep ?
// The profile curve is a degree=1 curve. Thus, the extruded surface will
// have kinks. Because kinked surface can cause problems down stream, Rhino
// always splits kinked surfaces when adding Breps to the document. Since
// we are not adding this Brep to the document, lets split the kinked
// surfaces ourself.
brep.Faces.SplitKinkyFaces(RhinoMath.DefaultAngleTolerance, true);
// The profile curve, created by the input points, is oriented clockwise.
// Thus when the profile is extruded, the resulting surface will have its
// normals pointed inwards. So lets check the orientation and, if inwards,
// flip the face normals.
if (BrepSolidOrientation.Inward == brep.SolidOrientation)
brep.Flip();
