must be something fundamental that I haven’t learned…
Deleting the dark form from the orange form not successful with red curve wirecut nor Boolean difference. Orange form too complex?
boolean fail -3.3dm (5.2 MB)
info for others that download the file - the upload is a rhino 9 file
you have to clean up the mess between the 2 dots (x)
more mess here:
if booleans fail - a good practices is to _intersect
there should be closed curves that define proper regions.
strongly recommended to work with layers - keep stuff in place - instead of dragging it around to a random position.
hide layers, not hide objects - this will make your document more readable / accessible and easier to fix errors.
hope this helps - kind regrads - tom
Rebuilt using a different sequence of operations. Now clean.
