Bongo 3.0 WIP 17 Now Available
Hi all,
** PLEASE NOTE - THIS IS WORK IN PROGRESS SOFTWARE **
USE AT YOUR OWN RISK.
Work-In-Progress versions are not production ready and may hang or crash.
Bongo 2.0 users are encouraged to download and try this WIP release of the animation plug-in for Rhino 7, Bongo 3.0.
Bongo 3.0 WIP 17 is now available from Rhino - Download - Bongo for Windows WIP
Rhino versions supported: Beta testing Bongo 3.0 is limited to Bongo 2.0 users. Bongo 3.0 requires a Bongo 2.0 license key. Latest version of Rhino 7.0 or 8 is required to install Bongo 3.0 and can be downloaded from:
Rhino 7 for Windows
Rhino 8 for Windows Dark mode not supported yet
Changes:
  • Bongo version switch updated with Rhino 8
  • Bongo version switch UI updated
  • Bongo Menu has been updated with more commands
  • Default “Draw point/dot every X ticks” has changed to 1
  • Animate button on the Timeline was updated
  • Feature added to select objects from a tick
Notes: This is the current work-in-progress release of Bongo 3.0 for Rhino. The product is in the very early stages of development any will probably change a great deal before release. This may include the file format, so please do not rely on Bongo 3.0 models working in the future. Bongo 3.0 will read Bongo 2.0 files, but will save Bongo 3.0 data only. This data cannot be read by Bongo 2.0, so please backup any files before using them in Bongo 3.0.
Was there the other day, but seems to have gone missing…
Thank you for reporting this. I logged it here. It will hopefully get fixed later today when Brian gets to work.
Any news?
The download link works again.
Great!
expired. pls wip 18 with 0 changes.
The latest WIP 17 should expire on 31 May 2024. I just tested and it works fine here.
Can you please send us your Bongo System report file? Sp we can have a look at what’s going on.
You can get the report by going to:
C:\Program Files\Bongo 3.0 (64-bit)
Right lick the BongoSystemReport.exe and choose to run as Admin. Save the file and send it to me.
You can send it directly to: marika.almgren@mcneel.com or as a PM here on the forum.
My apologies - my mistake. I’m on a second pc and didn’t notice the older versions. Sry. Everything is going fine.
I have a problem with Rhino 8.5 and Bongo WIP
Can you try loading it manually?
Open up Rhino 8 and go to Tools > Options > Plug-ins
Press the Install -button.
Go to:
select the BongoUI.30.v60.rhp and press ok.
Does it load now?
Very thank you. Its working!
How is possible not yet the MAC version?
The C++ SDK is still to be ported to the Rhino for Mac version and before that is done we’re not able to start the work. So at the moment we’re just focusing on the Windows version.
Any news?
:point_up: State is still the same.
