BlockEdit additional option wish
hi Guys,
It would be very helpful to be able to quickly access Block Properties from the BlockEdit dialog.
Maybe an additional button that would lead to the same window we get from BlockManager when clicking Properties? It would be a good quick way to access/edit this info without a need to go via many more clicks in Block Manager.
thank you,
–jarek
Hi Jarek - the goal is for quick access to block and sub-block properties though, correct? not especially to have it inside BlockEdit…?
hi Pascal,
generally yes, a quick access to selected block instance block definition properties dialog box would be nice. Currently you can create macro via scripted version of -BlockManager but it is harder to edit/preview via command-line only. Otherwise it is nested deep inside BlockManager. But specifically today when BlockEditing mutliple blocks it would be really handy to edit Block Properties at the same time as editing the block definition objects… that’s why the idea of a button there. Thanks!
–jarek
Got that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-56448
