Hello Rhino Com,
I am writing again to express my absolute frustration with what seems to be a no brainer feature to edit large block libraries.
When you double click on a block, it only brings up the name, but not the description. When you go to the properties, it is a generic panel of object properties instead of block properties.
After you find the little button for block properties, you have to go and manually find the block. At the very least, when you select the block, the cursor should highlight the block in the upper panel so you can easily edit its information.
Please, look into this, I am big on blocks & it helps give my drawings a punch, this feature would go a long way to keep files, blocks & drawings organized.
Thank you.
