I want to convert the block structure of step file to Layer. I would like you to share the script file related to the solution of the issue.
Hi Hakan -
If the script in the following thread doesn’t do what you want, please describe in detail what you are trying to do…
how can I use .rhp file? I use Rhino 7
As always, unblock after downloading.
Then drag-and-drop onto Rhino.
this is not working
Hello- what happens if you try - is there any feedback at all? Unblock and load the plug-in file, then run the command:
ExplodeBlocksToLayers
