So in the version 6.0.17178.4271 if I have a block on locked layer the display of that block gets turn off. Is that bug? It never used to be like that.
Hi Dennis - I make a block on Layer 02 (objects and block instance on the layer) and then lock that layer - I can still see the block - would that be a test for what you are reporting or is there more to it?
- Pascal
Yeah that is what I am I have, expect the block is a linked block. Here try this file. If I lock the x-ref layer in the P4 column area file the linked block get’s turned off.
415 P4 Column Areas.3dm (210.4 KB)
x-COORDINATION_OVERALL FLOOR PLAN LEVEL P4.3dm (694.2 KB)
He Dennis - I see that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-40375
I experienced that too.
RH-40375 is fixed in the latest WIP
