BlendSrf and MatchSrf has no Zebra analysis
When I have used in Rhino WIP last version, but the command BlendSrf and MatchSrf has no Zebra analysis. How can I do for this?
Zebra display does not work for me with BlendSrf using the Rhino for Windows WIP. (7.0.20084.11445, 3/24/2020)
Zebra display works for me with MatchSrf using the Rhino for Windows WIP. (7.0.20084.11445, 3/24/2020)
@Alen_Russ Which version of the WIP are you using? You can check with the AboutRhino command.
I have used with version 7.0.20071.5245, 2020/3/11.
Is there a check box on the blendsrf and matchsrf command dialog for zebra analysis?
No check box for Zebra in BlendSrf or MarchSrf and there is not a check box for either in V6.
I started Zebra analysis for the two surfaces to be blended or matched. In V6 if I use BlendSrf or MatchSrf the zebra stripes appear while using the comands. In V7 using BlendSrf the stripes do not appear on the blend surface until the command is completed.
OK. Thank you
