Blend Curve Pt (BlendCPt) by Script (C#)
is there a chance to access the function available in GH? Or can you show me how to exactly rebuild the curves coming out of this function? I need to automate this by a script.
Thanks and all the best,
Andreas
it is self-implement by the developer. There is no RhinoCommon.
What he does is, he creates Blendcurves …
Curve blend = Curve.CreateBlendCurve(curveA, curveB, blendContinuity, bulgeFactorA, bulgeFactorB);
… and iteratively increase or decreases the factors involved, until he reaches point X (as close as possible).
Therefore he measures the distance between the point and the closest point on the blendcurve.
Hello Tom,
thanks for the answer. That’s what I feared, so there is no chance to get the same outcome as from the GH function. Maybe some GH dev can reveal the optimization algorithm and the cancel conditions? I have to do it for 4 million curves, so there could be a performance issue.
You may ask where do I know this from? :slight_smile: Since its not nice to do such things, I won’t tell you how you can get such information, but it has something to do with a C# Decompiler…
Sure it is always an option, but I try to avoid methods like that :wink:
why? Maybe its not a good idea to share information about decompiling (although its pretty easy for dot.net), but for solving a problem and learning this is a very valuable source and morally totally okay in my opinion.
I decompiled, and in deed it is not even dotfuscated, but could not find the function. Any hints?
check curve components gha
and (maybe) this as well
Thanks! Found and rebuild as an open C# component.
