I have a strange bug with my RealTime display, but it seems I can reproduce it with the MockingBird sample too (“MockingRealTimeMode”).
In real time display mode if I create a ChangeQueue object (even if I don’t use it), and later I open another scene or a new empty scene in Rhino, it opens but all the viewports are black. (And I can not change it - tried to switch between different diplay modes…)
Let me test that with the plug-in here locally. If that were the case normally I’d expect such blackness to happen also with Raytraced mode. Does that happen for you too?
The problem is happening with opening channel on the RenderWindow. I’ve not been able to investigate further in the past two weeks, but it is still on my list. Thanks for the reminder.
Here I don’t have the lock at opening channel, but the final error is similar.
I don’t have this error it if I don’t create a renderQueue object, otherwise I have it even if it doesn’t do anything.
In you MockingBirdViewport sample if I comment out the lines in MockingRender.cs
I’ve been trying to figure out what is going on here, but with the sample from
I am no longer able to reproduce the hang. I realized that I was working of an old repository that is no longer in use. With the sample from above I get as one would expect. Upon switching to MockingRealtimeMode the viewport gets properly instantiated, along with the change queue. The viewport goes from black to full white in 50 samples, and the command-line shows output as expected. I did this while using the 6.16 SRC with a debugger attached. I think that maybe the problem here is access to the command-line - in reality one should not be printing anything there, and I guess with a debugger attached there seems less potential for lockups.
So could you please test on your side by taking out all usages of RhinoApp.WriteLine() from the change queue implementation in the viewport example?
I have commented out the RhinoApp.WriteLine lines, but unfortunately I still have this full black after I start a new scene. (tested in release and debug mode too)
My Rhino is Version 6 SR 15
Hmm, unlikely, I was testing before also on 6.16 when I saw problems - but that was due to running my old repository code. I’m compiling a release build of the sample and test again.
edit:
@marton.parlagh before you test the plug-in please ensure it is actually loaded by checking in Tools > Options > Plug-ins. If it isn’t right-click it and choose to load.
edit2: this plug-in doesn’t autoload when choosing the viewport mode from the drop list. Since it is a sample plug.-in I didn’t want it to autoload on Rhino startup, nor does it load when switching to the mode in a vp.
@marton.parlagh, first of appologies for getting sidetracked by looking at the wrong problem. In the end it was a small bit I had forgotten was necessary. I’ve committed and pushed a fix to the sample code:
The missing bit is cleaning up the ChangeQueue instance. That has
to be explicitly done, otherwise the display pipeline hangs like you noticed.
Sorry it took so long. It must have been the heat… (anything above 20°C is too hot )
I hope you can make good progress now. The most complete example is of course the code for the Raytraced mode itself…
Probably a lot to take in, but once you’ve got the basics under control using the viewport sample you’ll be able to understand better how Raytraced works
