Big Bug display on rhino 6 SR9
Hello everyone,
recently we have find a bogu with the rhino display
Try to move or copy the red object and rhino Bug appear !!! you can see the video.
bug display.3dm
https://smc2.box.com/s/kuebyvcxtpvhoj08ng50rineh7uwscoo
Video
Bug deplacement.zip
https://smc2.box.com/s/rffyamistred8crtzqaav8sox5drsozr
We have testing with a GTX or a Quadro card, and the bogu is present with the 2 cards :frowning:
My config is
Rhino 6 SR9 2018-9-18 (Rhino 6, 6.9.18261.20431, Git hash:master @ cd1f1f148472a45f7151959c62bf97c06889b541)
Licence type: Commerciale, build 2018-09-18
License details: Cloud Zoo. In use by: xxxxxxxxx SMC2 (Societe SMC2)
Windows 7 SP1 (Physical RAM: 32Gb)
Machine name: PC-BE30
Quadro K2200/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 392.00)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-30-2018
Driver Version: 23.21.13.9200
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.9.18261.20431
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files (x86)\Lynx\Lynx.rhp “Lynx” 0.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.9.18261.20431
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.9.18261.20431
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.9.18261.20431
Best regards
Does it still happen after you load-protect Lynx and restart Rhino? I did not see any weird behavior.
Hi thanks for your response.
Yes i have just tested by disabling Lynx and i have restart rhino. but the bug is againe present :frowning:
I am able to reproduce this here (no Lynx installed) sorta - by selecting certain combinations of objects and not others. But it’s not 100% repeatable, I can move, see the anomaly, undo, then redo and I no longer see it. Also depends on the direction of the move, I can only make it happen (sometimes) with moves that are perpendicular to the horizontal beam axis (in Y for example). This definitely looks like a display problem with blocks.
Then @stevebaer needs to have a look at this.
verry thanks
Hello - I don’t see this yet here… Does ClearAllMeshes and then shading again clear this up?
Hi Pascal, I have test the ClearAllMeshes command and the bug is present. :frowning:
Hi @pascal
Try these steps:
  1. Open the original file, don’t move the view.
  2. Set the display mode to shaded.
  3. Select the two smaller gray “brackets” and the 4 uppermost red “pins” you see (together).
  4. Move the selection in the Y direction with the green Gumball arrow.
  5. You should see the effect.
  6. Undo the move, leave the items selected.
  7. Try moving again in Y. You no longer see the problem.
Thanks Mitch - got it now (at least sometimes)- I think I tried every other combination…
https://mcneel.myjetbrains.com/youtrack/issue/RH-48745
