Bevel has been having errors
Bevel has been experiencing errors. When will it be fixed? It’s unusable
xj.3dm (2.4 MB)
stitch these edges and your model will work fine-
bevels added after fix
The poured result is uneven, resulting in a deformed outcome with uneven heights. Can you understand what I’m trying to say
4
you may have to add a bevel, then adjust the edges as your needs dictate.
Can’t these two be fixed yet
123.3dm (235.8 KB)
This issue has been fixed in the latest Rhino BETA. Test results are below. Could you please give it a try later? Thank you.
Got it, thank you. I’ll test it later
