Between command does not work fully.
When I am inside rotate command after selecting the center : when I use: 1. alias “_Between” it says:unknown command. 2. when I use the between button it works.
when I use the alias in other places its OK.
How can that be fixed?
Thank You
Solomon
Hmm, that seems to work OK here in both V5 and V6, but I have a US English system… Might be a language translation issue - what language is your OS/Rhino?
ENGLISH
The alias _Between works well in other places I used it
Thank you
Hi Solomon - ‘Between’ or ‘_Between’ should work - does here. Can you try what does not work and copy/paste the relevant lines from CommandHistory
(F2 key) here?
thanks,
Hi
Option 1(with alias bt=_Between) Command History:
1 surface added to selection.
Command: R
Command: _Rotate
Center of rotation ( Copy=No UseLastCenter )
Angle or first reference point <-56.0053> ( Copy=No ): bt
Angle or first reference point <-56.0053> ( Copy=No ): _Between
Unknown command: _Between
Second reference point <-56.0053> ( Copy=No )
Option 2(Button _Between) Command History
Command: R
Command: _Rotate
Angle or first reference point <-66.9367> ( Copy=No ): _Between
First point
Second point
Second reference point <-66.9367> ( Copy=No )
Thank You
Solomon
Hi Solomon - can you please also run SystemInfo
(Help menu > System information) and paste the results here? The problem you’re describing definitely rings a bell and I believe it, or something similar, has been fixed in more recent builds - I’ll look around for the relevant bug report.
Hi
Rhino System Information:
Rhino 6 SR2 2018-3-6 (Rhino 6, 6.2.18065.11031, Git hash:master @ cd4fa1dcdec31cb58baacef0855771173af7196f)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
GeForce GTX 1050 Ti/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.13)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-27-2017
Driver Version: 23.21.13.8813
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot7RhinoPlugin (486807a0-d332-4669-8086-e0497d91acd5)\1.1.0.0\KeyShot7RhinoPlugin\Rhino 5.0\x64\KeyShot7RhinoPlugin.rhp “KeyShot7RhinoPlugin”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.2.1.981\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
J:\DB(GH+TB+Setting)\Rhino\PluginInUse\InUSE\PetersTools1.91.rhp “PetersTools”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
