The Bend Tool works only by setting a starting point and end point for a spine, so you can use it only from one side.
Symmetry
I would like to bend an object symmetrically on both ends by picking the midpoint. -
Better Feedback
thanks
Symmetry
Better Feedback
thanks
1 Use the Symmetry switch in the prompt (which doesn’t show in the preview, but works fine). Also check the LimitToSpine=Yes/No switch if you need to bend only part of the curve.
2 Agreed, the preview is not good!
HTH, Jakob
Thank you @Normand
yes feedback is strange, it is not a precise tool where you can use it to construct, it seems like guesswork
