Best ways to simulate grid shell bending?
Here is another attempt using an elastic shell model and EQlib:
The trick is to model the flat configuration and prescribe an undeformed geometry to the lamellas. Then you can use the gumball to control the lifting.
Best
Thomas
Hi Daniel,
For more complex topology i.e. quad meshes with singularities, do you think the isothermic goal could be used to find the asymptotic network as you describe? If I’m understanding this correctly, the planar vertex stars may produce planar strips, but they would only follow principal curvatures if the mesh is isothermic?
edit - I should say, singularities with even number valences as you mention in another post - Ellipsoid mesh from curvature lines - #6 by DanielPiker
Hi everyone, I know this thread is old, but I hope I can ask for help. I’m working on generating minimal surfaces via the Koebe polyhedron method, but despite the scripts already shared, I still can’t get it to work. This is my GH file — I’d be very grateful if you could take a look and offer guidance when you have time.
1.gh (22.0 KB)
