Best practice - version control in Rhino Script Editor with GH components
@kiteboardshaper
Great questions.
What I do internally is that I use git as my source control and save my grasshopper definitions in .ghx file format so they are text-based and easily handled by git. Then all my script editor project file (*.rhproj), scripts, and grasshopper definitions can live in the same git repository.
I can add an option to “Replace” a definition in the script editor project with another definition, OR, you can also manually edit the .rhproj file (it is JSON) and change the Grasshopper definition path to the new one. In this case I would suggest duplicating the .rhproj file for each release.
The +0000 number after the version is the build number and is computed automatically based on current date time. For example if you build 25.5.19 multiple times during development to test, the build number differentiates each specific build.
