Hello all!
Does anyone have a script that will run a mesh for all objects on varying layers and move the mesh to a the respective parent sublayer with the format “parentlayer”-mesh?
Any help would be appreciated!
Thanks,
dsuhay
Hello all!
Thanks,
dsuhay
Try something like this:
import Rhino
import scriptcontext
filter = rs.filter.polysurface
objIds = rs.GetObjects('Select objects for meshing', filter)
params = Rhino.Geometry.MeshingParameters()
for objId in objIds:
objLayName = rs.ObjectLayer(objId)
brep = rs.coercerhinoobject(objId)
if brep.ObjectType == Rhino.DocObjects.ObjectType.Extrusion:
brep = Rhino.Geometry.Brep.TryConvertBrep(brep.Geometry)
else:
brep = brep.Geometry
try:
meshes = Rhino.Geometry.Mesh.CreateFromBrep(brep, params.Default)
layers = rs.LayerNames()
#print layers
meshLayName = "{}_MESH".format(objLayName)
if not "{}::{}".format(objLayName,meshLayName) in layers:
rs.AddLayer(meshLayName)
rs.ParentLayer(meshLayName, objLayName)
for mesh in meshes:
id = scriptcontext.doc.ActiveDoc.Objects.Add(mesh)
rs.ObjectLayer(id, meshLayName)
except:
continue
